Looking for multi-region DVD / Blu ray player recommendations
cactusj
It has been several years since I have bought a DVD player - my last purchase 4 years ago was a DVD player that I made multi-region by using the remote to enter a simple code found on a website.
I am now looking for a Blu ray player that can play multi-region DVDs - the Blu-ray disks can be UK specific and not multi-region.
I have spotted this from Richer Sounds - Sony BDPS1100 - the title specifically notes that the DVD playback is multi-region.
http://www.richersounds.com/product/blu-ray/sony/bdps1100-mr/sony-bdps1100-blk-mr
I may also buy a spare multi-region DVD player:
http://www.richersounds.com/product/dvd-players/sony/dvpsr170-mr/sony-dvpsr170-mr
Which is also region-free according to the website.
Can anyone indicate how reliable this is likely to be - are both players likely to be multi-region DVD straight out of the box? Does anyone have any experience buying from Richer Sounds?
Can anyone recommend any other multi-region DVD / blu-ray players similar to the ones above (i.e. multi-region out of the box)
Many thanks for any advice.
4 REPLIES 4
RPMozley
Seasoned Pro
Fixes: 16
Re: Looking for multi-region DVD / Blu ray player recommendations
If they are labeled as multi-region then they will be 'out of box'. I bought our Sony DVD-recorder / HDD as multi-region and has worked pretty much flawlessly with regards to the region bit. Due to a mess up by the Freeview guide people it did make it inoperable for a while with it being stuck on updating the EPG but that's not really anything to do with the DVD part.
That's RPM to you!!
JamesM
I haven't bought a multi region Blue Ray player so I can't help you with that, but I have bought a few things from Richer Sounds in Sheffield, and I can highly recommend them.
http://www.avforums.com/
http://www.avforums.com/forums/blu-ray-dvd-players.148/
Check out this sites forum, I always read here before I purchase anything.
HTH
kmilburn
From the look of it,  by default that player is not multi-region.
However, there's a fairly trivial method of making it multi-region, if you've got the right remote control.
This is likely what Richer Sounds are doing, as the mutli-region player is £10 more than the single region version.
Now,  if you want multi-region Blu-Ray too, this is an option from Multiregion Magic  (A good company I've used a few times).
cactusj
Thanks everyone. I have bought from Richer  Sounds.
