Localphone issues
Fixes: 583
Re: Plusnet Full Fibre
@Teece  did you get the Localphone issues sorted ?
Teece
No, still waiting for them to pick up the ticket.
Fixes: 583
@Teece does the N300 show any status code when you try to call ?
Teece
Hmm, where would I look? Can't see anything obvious in the Web UI.
Fixes: 583
It usually show the status code on the handset
Teece
Fixed at the LocalPhone end just now. Thanks for all the suggestions.
Fixes: 583
Did they say what the problem was ?
Just in case others have acsimilar issue
Teece
The response didn't say, but I have asked. I'll update here if there's any meaningful feedback.
Teece
Apparently, caller ID wasn't set correctly. UK law says that a call can't be made from a number that can't be called back.
Fixes: 583
AIUI by default, unless you associate a 'real' number with your account , it will set a caller ID of your SIP ID.
I have two numbers associated with my account and have four options to set caller ID
either of the 2 numbers, SIP ID and Hide caller ID.
They appear to be saying that if you set it to SIP ID , then external calls won't work.
GC6 says
General Condition C6 requires communications providers to provide CLI facilities, unless they can demonstrate that it is not technically feasible or economically viable to do so. Where CLI is provided, it must include a valid, dialable telephone number which uniquely identifies the caller.
So I guess they're correct, but then why provide the option to set it to SIP ID ? I guess it's only a requirement in the UK.
