Localhost message
FIXED- Subscribe to RSS Feed
- Re: Localhost message
29-06-2016 11:18 PM
Wanted to check my router stats earlier this evening, but when I logged into my ASUS DSL-N55U it wasn't generating any information. I had a look through several of the other menus and noticed the following message
dnsmasq-dhcp[8633]: not giving name localhost to the DHCP lease of 192.168.1.196 because the name exists in /etc/hosts with address 127.0.0.1
After some detective work it seems that my son's Samsung smart tv is the culprit. I have been into the settings and made sure it has a unique name that should show on the device list, but it's still showing as localhost ![]()
Anyone have any ideas where I can change the name of it other than on his tv. There appears to be no option on the router.
Fixed! Go to the fix.
30-06-2016 7:42 AM - edited 30-06-2016 7:42 AM
There is a lengthy discussion on this issue here: http://www.snbforums.com/threads/rt-ac68u-hostname-conflict.26264/page-2 . The problem seems to be particular to Asus routers and there is some sugggestion that updating the router firmware might fix it. Or there seems to be some customised firmware called "Merlin".
30-06-2016 11:49 AM
It appears it's Samsung's fault for how they have named their device. May have to do more trawling of forums as that one doesn't relate to my router, and I don't want to download firmware that could be wrong and make it worse.
30-06-2016 1:03 PM
Fundamentally it's Samsung's fault but Asus routers seem to be more pernickety about it than others. Since there does not seem to be a remedy at the Samsung end you may have to persuade your Asus router to be less fussy.
30-06-2016 3:20 PM
Not really sure how I can do that as it doesn't appear you can rename the connection at the router end ![]()
Anything more than that is beyond my technical ability.
30-06-2016 7:59 PM
So does the TV fail to get a connection to the internet?
30-06-2016 8:26 PM
No the TV says it is connecting to the internet, and my son has used it to access Youtube, so I assume it must be.
However, I have managed to upgrade the firmware to ASUS DSL-N55U Firmware version 3.0.0.4.376_2736 and this has now given me the option to rename what was showing as localhost to something more relevant and it seems to have stopped the message I was getting regarding it.
