Linux software
- Re: Linux software
- « Previous
- Next »
Re: Linux software
21-01-2012 6:17 PM
The "failed to open device" message suggests the scanning program didn't get very far, either it could not find the filename of the device it was expecting, or couldn't open it due to permissions problems.
You may find some more messages in the system logs - open Log File Viewer from the applications menu.
Is there actually a "snapscan" program? Try xsane.
Re: Linux software
21-01-2012 7:26 PM
Quote from: gleneagles ls
CONF etc mozilla.pdf Templates
Desktop firefox Music Untitled1.pdf
dir Firefox_wallpaper.png Pictures Untitled2.pdf
Documents Graphics ppdMP620-630en-1.5 usr
Downloads iscan-2.10.0 Public Videos
Esfw41.bin iscan for scanner scanner XSane
The existence of files/directories such as etc, usr would seem to indicate a seriously peculiar setup.
Perhaps you have copied some of your system files into your home directory???
Re: Linux software
22-01-2012 2:48 PM
Looking at the log viewer I also get errors about the log viewer ! ie
Log Viewer: Could not open the following files:
/var/log/bootstrap.log/error starting file '/var/log/bootstrap.log: No such file or directory
/var/log/fontconfig.log/error starting file'var/log/fontconfig.log: No such file or directory.
So I guess the best course of action is to do nothing further as the rest of the OS appears to be working ok, or at least the bits I am using and keep going until such time as I need to do a full reinstall and at that point have another attempt to get the scanner working.
NB: There is a snapscan program but clearly it cannot link with the scanner as it comes up with the following when I try to scan,
Error failed to open Device.
Snapscan:libusb:002:003
Error during device I/O
Re: Linux software
22-01-2012 3:22 PM
I can't find any trace of a program called "snapscan". There's no snapscan program on Fedora or Ubuntu. Try xsane (GUI) or scanimage (command line). What does the "scanimage -L" command say?
Re: Linux software
22-01-2012 3:42 PM
The Epson 2480 is supported and there are install/configure instructions at the bottom of the web page for using with SANE.
BTW Any reference to your current kernel version can be taken to be at least 2.6.
However,
First find out the nature of those etc, usr files or directories.
Unless you know what they are, I would rename ~/usr to ~/usr_x and similarly with ~/etc
It is just possible that their current names could upset your install scripts.
Re: Linux software
22-01-2012 4:27 PM
Quote from: ejs So the Log Viewer is configured to try and open some log files that don't exist - doesn't seem to be a big problem really. /var/log/messages is the main system logfile.
scanimage -L
device `snapscan:libusb:002:003' is a EPSON EPSON Scanner flatbed scanner
Re: Linux software
22-01-2012 4:50 PM
Bareword found where operator expected at (eval 1) line 1, near "/home/duncan"
(Missing operator before duncan?)
syntax error at (eval 1) line 1, near "/home/duncan"
Re: Linux software
22-01-2012 5:04 PM
Quote from: gleneagles Must admit this is getting above my head, following message when I try to rename file,
Just use the file manager?
Quote from: gleneagles scanimage -L
That looks OK, what about trying "scanimage --test --verbose"?
Re: Linux software
22-01-2012 6:12 PM
Quote mv ~/usr ~/usr_x
mv ~/etc ~/etc_x
Re: Linux software
22-01-2012 6:44 PM
Use xsane, easy and works. (Under Graphics on my pc, you may need to install it from Synaptic) or simple-scan (for an easy to use scan and forget program)
Re: Linux software
22-01-2012 8:22 PM
Quote from: Hairy OMG that program was last updated "June 25, 2004" Don't use it.
Which program? The scanimage command line tool that's part of sane-backends and is mainly useful for testing and debugging?
Re: Linux software
23-01-2012 9:01 AM
Quote from: ejs
Just because a program hasn't been updated does not make it any less usable. I have a program (written for Windows in the early 1990's) has not been updated or supported since, but still works perfectly. I used it under Windows up to XP and Ubuntu from v6.04 to v10.04 LTS (my current version) with Wine.
Re: Linux software
23-01-2012 10:05 AM
An example of this is Nero (V3). It works fine in Mint 11 (G2) but under Mint 12 (G3) it just errors saying it can't find the language files. I assume Nero 4 would work but I am not paying to get an upgrade, having already paid to move from M$ to Linux. (That and the fact you get a full demo (unlimited) package under M$ not Linux where it times out in 30 days)
Quote from: Ellis I have a program (written for Windows in the early 1990's) has not been updated or supported since, but still works perfectly. I used it under Windows up to XP and Ubuntu from v6.04 to v10.04 LTS (my current version) with Wine.
Yes but would it work under W7? And M$ programs are notorious for not being updated/charging for updates.
Re: Linux software
23-01-2012 10:12 AM
Quote from: gleneagles That looks OK, what about trying "scanimage --test --verbose"?
scanimage: open of device snapscan:libusb:002:003 failed: Error during device I/O
Rather interestingly this is the first time I heard the scanner try to start up after using this command.
dick:green Quote fixed.
Re: Linux software
23-01-2012 10:30 AM
No one more amazed than me !
I Ran the scanimage test and got the message shown in the previous post.
I Then renamed the files as suggested by a Fox is evil and that seems to have done the trick.
Many thanks to those who have contributed to this topic.
- « Previous
- Next »
