Linux software
HairyMcbiker
All Star
Fixes: 21
Re: Linux software
Quote from: gleneagles
[First line downloads the file ok but when I run the second line I get,
If the first line completes successfully then the file SHOULD be there. try "ls *.bin" and check the folder.
Alternate way (32!)
sudo -s
cd /usr/share/sane/snapscan
wget http://luc.byhet.free.fr/epson2480/esfw41.bin
exit
This way it is placed DIRECTLY into the destination folder. But as I said before keep a copy save somewhere.
gleneagles
Aspiring Legend
Fixes: 17
Re: Linux software
The file is there but still get an error message,
sudo mv /home/duncan/esfw41.bin /usr/share/sane/snapscan
mv: cannot stat `/home/xxxxxx/esfw41.bin': No such file or directory
I Will keep playing around with this as clearly it is something quite simple that I am failing to do but having spent hours on it I have no intention of giving up.
Out of interest have you any thoughts about the kind of  simple error a beginner in Linux is likely to make on this specific topic ?
We are born into history and history is born into us.
gleneagles
Aspiring Legend
Fixes: 17
Re: Linux software
--2012-01-12 16:17:44--  http://luc.byhet.free.fr/epson2480/esfw41.bin
Resolving luc.byhet.free.fr... 212.27.63.149
Connecting to luc.byhet.free.fr|212.27.63.149|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 64000 (62K) [application/octet-stream]
Saving to: `esfw41.bin.2'
100%[======================================>] 64,000      133K/s  in 0.5s
2012-01-12 16:17:45 (133 KB/s) - `esfw41.bin.2' saved [64000/64000]
so the file is there
gleneagles
Aspiring Legend
Fixes: 17
Re: Linux software
and Linux can clearly see the scanner,
Bus 002 Device 003: ID 04b8:0121 Seiko Epson Corp. Perfection 2480 Photo
ejs
Aspiring Hero
Fixes: 25
Re: Linux software
You can put the firmware file anywhere you like, as long as you edit /etc/sane.d/snapscan.conf and put in the full path and filename.
CX
Re: Linux software
How about if you try to do it via the GUI (although I'm pretty sure this will fail)
Launch the Nautilus file browser elevated:
sudo nautilus
And copy/paste or drag/drop the file.
gleneagles
Aspiring Legend
Fixes: 17
Re: Linux software
I am fairly new to Linux & have no experience with editing files or dealing with pathnames etc,
To be honest I would rather stick to a GUI but on this one occasion have had to go down this path in an attempt to get my scanner to work.
gleneagles
Aspiring Legend
Fixes: 17
Re: Linux software
Quote from: CX23882
sudo nautilus
no that doesn't work.
If I keep getting the message no such file or directory is this telling me it can't find xsane or simple-scan (which have both been installed using apt-get)
To be honest I will have to leave this for a day or so and come back to it as I have run out of options to try.
HairyMcbiker
All Star
Fixes: 21
Re: Linux software
Ok you seem to have multiple copies?
Note the .2 on the end. maybe that is what is causing the issues?
As to newbies and this particular scanner, for 90+% of people they don't use a scanner or it just works like my Canon one. (Much like wifi, when it doesn't it can be a real PITA)
If the .2 is the issue, then try
mv esfw41.bin.2 esfw41.bin
sudo mv esfw41.bin /usr/share/sane/snapscan
which will rename the file and then copy it.
ejs
Aspiring Hero
Fixes: 25
Re: Linux software
wget isn't going to create esfw41.bin.2 unless esfw41.bin and esfw41.bin.1 already exist.
Regardless of where you put the firmware file, you still have to edit the /etc/sane.d/snapscan.conf file.
HairyMcbiker
All Star
Fixes: 21
Re: Linux software
I was wondering about that, since he says he can't find the file when he tries to copy it. That was why I suggested mv the the .bin rather than the .bin.2.
gleneagles
Aspiring Legend
Fixes: 17
Re: Linux software
still getting,
mv: cannot stat `esfw41.bin.2': No such file or directory
What I am going to have a go at over the weekend is to attach the scanner to a second computer I have (also running Linux) and see if it comes up with the same messages.
Not knowing much about the subject I wonder if I have downloaded something that is causing it to clash with this program ?
I Know little about Linux, it works fine but if there was something wrong would I get error messages ? I have used Bleachbit a couple of times could it have wiped something essential ?
VileReynard
Fixes: 20
Re: Linux software
O.K. !
In a terminal screen type
sudo nautilus
This should give you a GUI file manager - but you have full access to add/delete anything - so think twice before doing anything.
You should be positioned in your /root directory, so navigate your way around to your /home/duncan directory.
This should contain your esfw41.bin files and you can copy and paste one of them to your /usr/share/sane/snapscan directory.
Close your GUI window as soon as possible.
If the terminal screen window displays any errors, ignore them.
Waldo
Re: Linux software
Despite downloading a variety of files for an Epson 2480 Photo Scanner I am unable to get it to work [...]
Has it never worked (I thought you'd got it working here)?
gleneagles
Aspiring Legend
Fixes: 17
Re: Linux software
Waldo,
Sorry that post was in error, everything downloaded and appeared to install correctly ok so I assumed when I came to use the scanner it would function ok.
I should have checked before posting.
