Lagging issues on PS4
shellbell118
I recently had an engineer out for a fault causing slow speeds. Since the visit one of the PS4's being used is suffering lag whilst playing online games. Other devices such as a separate PS4, laptop and phones are all fine. Any help or suggestions would be appreciated.
3 REPLIES 3
RPMozley
Seasoned Pro
Fixes: 18
Re: Lagging issues on PS4
How are each of the devices connecting to the internet, are there any differences? Also what router is being used?
That's RPM to you!!
shellbell118
Thanks for your reply.
All devices are connected via wifi.
The router is Plusnet Hub 2 (I think) lol.
RPMozley
Seasoned Pro
Fixes: 18
Have you checked the signal quality around the area of each device’s location? Maybe a neighbour’s WiFi is interfering for the problem PS4?
That's RPM to you!!
