Hub2 mesh
Axwell
Hub2 mesh
I have a hub2 router but there are wifi dead spaces around the house. Is the hub2 a mesh router... and if it is are there any mesh nodes which people have found work well?
2 REPLIES 2
Fixes: 1,495
Re: Hub2 mesh
Moderators Note
This topic has been moved from Broadband to Tech Help
Re: Hub2 mesh
@Axwell welcome to the forum.
The bad news for you is the Hub Two is not a mesh router.
You could purchase a mesh system which support PPPoE connections and configure the Hub to bridge mode (modem only)
HTH
