Kindle Battery
gleneagles
Aspiring Legend
Fixes: 17
Kindle Battery
As my Kindle has been used a lot the length of time the battery stays charged has decreased by a considerable amount. (as expected)
There are numerous you tube videos showing how to change the battery but the question is this, will any books currently on my Kindle be lost as soon as I disconnect the old battery ? Could I just drag the document folder on the Kindle to a computer and just drag it back again once a new battery was installed ?
Anyone else changed a Kindle battery or know of any links that specifically relate to my query regarding loss of data when changing the battery ?
We are born into history and history is born into us.
3 REPLIES 3
shutter
Fixes: 67
Re: Kindle Battery
here is a linky to a "how to.... "  http://www.ifixit.com/Guide/Kindle+Fire+Battery+Replacement/7741
and another one...  https://www.google.co.uk/#q=how+to+change+a+kindle+battery
a couple of posts on here.... http://www.amazon.com/forum/kindle?_encoding=UTF8&cdForum=Fx1D7SY3BVSESG&cdThread=Tx3RR8AID4HJ60J
seem to contradict each other  ( not deliberately !)... one says you WILL lose your books..... the other said their books were still available after battery change..
I've had a Kindle Touch completely apart to replace a broken screen, and the battery was removed to do this. Books remained on the Kindle. It's drive is pretty much the equivalent of a flash drive. Even the screen picture will remain through the battery removal until it reboots when you start it back up.
and
To answer your question, in most cases removing the battery will clear the memory, so you will probably have to redownload all your books.
This one seems to be more definite....  http://askville.amazon.com/Kindle-loaded-20-30-books-battery-dies-lose-purchased-downloaded/AnswerVi...
No, for two reasons:
1_ the contents of the titles (the files) are written to solid-date memory chips, and they do not lose their memory even if power is lost. When you recharge, your books are intact.
2_ Even if something happened physically to your device, Amazon's computers keep track of your purchases and would allow to redownload if necessary.
gleneagles
Aspiring Legend
Fixes: 17
Re: Kindle Battery
Many thanks for the links, some interesting information there.
As you say some people indicate the books will be lost whilst others do not. It has been suggested that books lost could be downloaded from Amazon and that's true in cases where you have purchased them from Amazon in the first place,I also understand it's also possible to upload some books to your amazon account which have not been purchased from Amazon and then download them to your kindle but that's getting a bit complex for me.
I Haven't noticed any comments in these articles about copying your amazon folder containing your books to a computer and then moving it back to your Kindle should books be lost following a battery change. In theory it should work as it's just moving/copying data from one device to another and then back again.
valart
Re: Kindle Battery
I am about to buy a tablet probaly a Tesco Hudl from what you said I just wondered on normal use how long is the battery life I suppose if one is watching films and playing games life is going to be short I might have second thoughts from what you said,it would be nice just to click open and replace the battery.Is it easy to replace a new battery I have seen it on you tube and it seems a bit tricky.
