Is it worth paying extra for a Windows optimisation service with a new PC.
- Is it worth paying extra for a Windows optimisatio...
- « Previous
- 1
- 2
- Next »
Re: Is it worth paying extra for a Windows optimisation service with a new PC.
11-04-2014 11:57 PM
@ Glenn
sorry to say but was the worst ever software i have ever used as suggested from PN forums , in fact i would say it worse than you get from DL.com
and i decline all the bloatware that was included in the DL and still got infected !!
i had in the end to uninstall FF and reinstall it !!! because i couldn't get rid of the search BHO included , yes i did try " Hijack this" as well as MAlwarebytes
It may have been good but didnt try because of the poop included
12-04-2014 5:09 AM
I'll be getting a custom built pc later in the year and I'll be getting Windows 7 Pro for it, I'm wondering if you got the exe file for 7 Smoker Pro from the xp smoker official site or a third party site.
I'll be looking into it more before I get a new rig....thanks for the heads up.
12-04-2014 7:54 AM
I download from the link you provided .
12-04-2014 1:38 PM
Oh gawd right...I thought you'd tried it before and were telling us about it.I've had the 7smoker.exe scanned by online virus and malware scanners and the two sites I used give it a clean bill of health...Virus Total scans it with many different anti virus and anti malware programmes and Dr Web gives it the ok as well.
https://www.virustotal.com/en-gb/file/17bd875b76b60688fabb72bdecb71e5281b3fa186e0391bb9260dd6abc7147...
http://online1.drweb.com/cache/?i=f436f314106e50f7abff11ad2f1d1021
PUP's don't mean you're infected, they're given as something you might want to look further into but don't mean they're necessarily harmful.I think you said a search bar was installed in your Firefox browser, that's happened to me before, there's no need to reinstall the browser to fix it, a quick google search will give you instructions on how to easily remove it and put your browser back to how it was.
As I said previously, I have XP Smoker Pro on my pc and I didn't get any browser guff and I don't even see any ads when I use it.
12-04-2014 5:08 PM
it wasnt Smoker that was the problem ,, it was the other add on free unwanted auto installs that came with download package
14-04-2014 8:56 PM
Bit of a joke - you pay money for an operating system and you want to (presumably) pay more money just to make it work a bit less slowly.
Windows seems to be very complicated.
14-04-2014 9:03 PM
It is like buying a car
It does need to be maintained to be kept in tip top condition
Some people do not have the skills & or knowledge, therefore they will pay a garage / friend / family member to service & maintain that it is kept in tip top condition
14-04-2014 9:50 PM
It's software.
You don't have to change the oil or check for bits falling off.
14-04-2014 10:59 PM
Self explanatory tbh
[quote= http://www.smallbusinesscomputing.com/thebasics/features/article.php/3705011/Preventative-Maintenance-Tips-for-Your-PC.htm]Computer failures occur for a variety of reasons, sometimes because of human error and sometimes because of factors in the environment that cause a computer to malfunction — or a combination of both. These factors can include excessive buildup of dust, heat or magnetism; viruses picked up from the Internet or from storage media shared between different computers; static electricity shocks or power surges; carelessness, such as spilling liquids into a computer or bumping or dropping the hard drive casing; software that has not been configured correctly or a PC's setup that has been handled incorrectly, such as incorrect handling of upgrades.
- « Previous
- 1
- 2
- Next »
