Is CWMP/TR-069 traffic blocked?
DaisyBoy
I am working from home and want to test a service for someone.
It involves using a Technicolor router on the end of my Fibre broadband.  This is all up and running and I have Internet access fine.
The router should be connecting back to a CWMP/TR-069/ACS server automatically, but the connection doesn't seem to get there.
Does anyone know if CWMP/TR-069/ACS traffic is blocked within (or at the perimeter) of the PlusNet network?
2 REPLIES 2
Fixes: 1,495
Re: Is CWMP/TR-069 traffic blocked?
On one level it's not blocked as PN update their routers using TR-069.
However, whether it works for non-PN traffic I don't know.
bobpullen
Fixes: 331
Assuming you don't have the server side Plusnet firewall enabled, then no - it isn't blocked. Are you able to browse to the ACS URL? Can you run a trace route to the ACS server?
