Internet Explorer: Microsoft plans 'silent' updates
- Internet Explorer: Microsoft plans 'silent' update...
- « Previous
- 1
- 2
- Next »
Re: Internet Explorer: Microsoft plans 'silent' updates
20-12-2011 9:10 AM
http://www.thinkbroadband.com/news/4937-internet-explorer-to-join-the-automatic-update-crowd.html
[quote=thinkbroadband]The problem with Automatic Updates from any application is that they are invariably unaware of any billing implications. This means that many road warriors have Automatic Updates turned off, to avoid using up precious mobile broadband allowance when travelling. The biggest danger will occur when roaming outside the EU, where just 1 MB of data can end up costing several pounds.
21-12-2011 9:49 PM
Quote from: ReedRichards
Quote from: pierre_pierre from those it looks like you have to instal a blocker program and not just tick a box on the update list.
I think the blocker program is for centrally-administered business computer networks where automatic updates are otherwise applied by default. It is much easier to run a program by means of a single instruction sent to every computer than to individually visit each computer on your network in order to untick a box to prevent an IE update being applied.
Corporates would certainly want a blocker available
They can get into all sort of trouble with "certified" applications if a part of the application (IE) is changed.
They will need to change their agreements such that IE is now regarded as part of the OS rather than a separate program....or no sorry I forgot, MS got into all sorts of trouble in the EU over precisely this thing
- « Previous
- 1
- 2
- Next »
