Installing extra memory - this might be more complex than it looks!
I want to install another 6Gb of memory on my Asus Rampage III Extreme motherboard. At present there are 3x2Gb memory sticks installed occupying three of six memory slots. There are three vacant slots into which I want to install the new memory sticks (which are identical make, size and type). OS is W7 Ultimate 64bit.
I have tried it already, and on boot up the POST is often not reporting the correct new RAM size. When it does this, W7 is thrown completely and shows BSODs when it does run (caused by various inconsistent errors, no pattern to it), and when it doesn't W7 just recycles waiting for a diagnostic disc. Taking the new memory out returns everything to normal.
Yes, I have had the memory exchanged. It was tested and found to be ok, but the exchange memory is still showing the same problem so I doubt it is also faulty.
Trawling round the web has thrown up various references to the BIOS having to create a memory map when the memory is first installed. This is kept until it is remade, and it appears that what might be happening is that W7 wants to use all the available memory, but when the BIOS is failing to detect it, there is obviously a mismatch and problems arise. The stock answer is to force the memory map to be remade. This particular motherboard doesn't have a "remap memory" option, so I suppose the obvious way is to shut down, install the extra memory, reset the BIOS by inverting the BIOS battery, reboot and reset the BIOS options.
I've upgraded memory many times in the past by simply inserting it and rebooting, but this is the first time I've ever come across anything like this. Has anyone else had this experience? All replies gratefully received! I'm reluctant to proceed as the current setup is working fine.
No broke, no fix!  Cheesy
Re: Installing extra memory - this might be more complex than it looks!
You have to have Matched pairs of DIMM's hence the BSOD's, think of it as 6 slots of 3 Pairs not 6 slots of singles.  So take one of your current DIMM's out and fit 2 of the new ones and check.
A quick google and the slots are colour coded blue/orange so one each of the pair should be in neighboring slots
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 173
Quote from: nozzer
That, to me sounds highly inadvisable. Usually there are two pins on the motherboard that are temporarily shorted with a jumper to reset the BIOS to default.
Customer and Forum Moderator. Windows 10 Firefox 63.0.3 (64-bit)
Quote from: Gus
It's triple channel memory, and there are three matched sticks in each channel. Won't work with just two in.
Fixes: 5
Shocked
Wow.  I'm so out of touch with PC hardware nowdays :/
Kelly Dorset
Broadband Service Manager
Fixes: 25
Quote from: nozzer
If that is true then there should not be any problems.  If you read your manual http://support.asus.com/Download.aspx?SLanguage=en&m=Rampage+II+Extreme&p=1&s=29 it says (Page 2-16): "Always install DIMMs with the same CAS latency" so even quite a subtle difference between the DIMMs could cause problems.  Also, by and large, the recommendation is NOT to install in pairs (see Page 2-15).
Fixes: 25
Quote from: nozzer
Yes it will (according to your manual P2-15).  Two, three four and six memory sticks are viable configurations.
All channels are filled with identical sticks, same latency, type, manufacture etc.
CX
Have you tried a slight voltage increase for the memory (say +0.1V)?
Fixes: 25
Have you tried the three new ones instead of the three old ones
Yup!
Just doing a BIOS update to see if that makes any difference. There's nothing in the BIOS release notes to say that it should.
Fixes: 25
Bottom of P2-16;
"For system stability, use a more efficient memory cooling system to support a full memory load (6 DIMMs) or overclocking condition".
Does that mean: "Full memory load (6 DIMMs) does not give you a stable system unless you take extra precautions"?
JamesM
I had the same problems with some Dominator memory, I had a 1 gig and a 512 Mb and I bought another 2 1 gig sticks. I could not get the new ram to work with the old ram even though they were the same make and spec. After trawling through loads of sites I found out that memory has revision numbers and even if it is the same spec and brand, if the revision numbers are different you can have problems.
Sorted!
BIOS with a patch required to install a "memory recheck" feature, whatever that is.
Thanks for all your help folks...    Smiley
Quote from: Strat
Quote from: nozzer
@Strat...  I got that idea from here.  1min 25sec...
