Installing HP Smart in WIndows 11 Laptop
G3WYP
Canm anyone help me please. I have a new HP Printer which requires HP Smart to run its various facilities.
When I download the app from Microsoft store as directed it starts to install then a window appears saying retry later etc.
I contatced HP support and we had  the same problem but when we installed onto a windows 10 laptop all was well.
The HP Tech person said he thought it might be something blocking the app on the Windows 11 laptop but couldn't help me.
There is no VPN on the laptop and I even tried with the anti virus stopped to no avail,
Can anyone point me in a direction that might allow me to install the software.
12 REPLIES 12
Shep41
Seasoned Pro
Fixes: 7
Re: Installing HP Smart in WIndows 11 Laptop
Have you tried right clicking the install icon and run as administrator?
G3WYP
Shep41. No I have not but will give it a go. Thanks
Gel
Champion
Fixes: 29
Fixes: 146
@G3WYP
Did you get anywhere with this? I have HP smart installed on Windows 11
There is also a mobile app for HP smart available from Google Play and Apple Store.
G3WYP
I cannot get administration to run on the app for some reason. Could it be it is downloaded from the Microsoft store unlike a normal programme.
G3WYP
I have it running on my mobile phone ok but still nothing on womdows 11 laptop.
Not helped with my broadband and phone going down several times in last 24 Hrs.
Fixes: 380
In that case:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
G3WYP
John. Not with Plusnet but with Sky unfortunately on Full Fibre. But hopefully moving soon.
Fixes: 146
@G3WYP
Are you downloading "HP Smart Installer.exe" or View in store? I'd try a download if you've not tried already
Edit: With my HP Envy 5000 I am able to manage it using it's Embedded Web Server connecting using its IP Address
Fixes: 380
Ooops - forgot, sorry (and my sympathies 😀)
G3WYP
Yes download that from the Microsoft Store.
Fixes: 146
Windows 11 - I have uninstalled and installed the app with no issue running the app afterwards. Are you trying to create an account or login into one  I'd try skipping that step.
