Hub One Router with USB stick for NAS
MichaelG6
Hi Guys,
What's the biggest size USB stick I can safely use for NAS on my Hub One Router ?
2 REPLIES 2
Fixes: 392
Re: Hub One Router with USB stick for NAS
I do not believe you can use the USB port on the Hub for that purpose, but I could be wrong.
@MichaelG6
The Hub One and Hub Two USB port only supports SMB v1 which is now obsolete, I suggest looking for a different share alternative.
