How unsafe is Windows XP
- How unsafe is Windows XP
31-10-2013 10:44 AM
Please don't bring Linux into this discussion
Re: How unsafe is Windows XP
31-10-2013 10:49 AM
As XP systems have, by definition, been around longer there's a lot more opportunities for users to "let things slip".
I've seen plenty of badly-infected Vista and W7 systems lately (pro-rata probably more than XP TBH) but there are too few W8's around to form a view yet.
31-10-2013 12:03 PM
Quote Redmond is urging laggard Win XP users to upgrade their machines before security updates for the OS end on 8 April 2014. ®
Of course they are urging you to BUY more M$ products. I notice that the latest Mac release was FREE.
31-10-2013 12:05 PM
Vigor 130 modem, pfSense 2.4.5-p1 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
31-10-2013 12:12 PM
31-10-2013 3:46 PM
Having said that - this is very interesting http://www.aidanfinn.com/?p=11912 - it may be possible without needing a cut down version
31-10-2013 3:57 PM
There are some technical requirements which some processors may not meet, but I think I've used basic Dell systems at least 10 years old without issues.
31-10-2013 4:20 PM
oh... one thing that is not available is the ability to change desktop wallpaper pics...
31-10-2013 4:55 PM
There's no equivalent with Windows 8.
Quote from: shutter I am running Windows 7 Starter
There is an RT edition for specific ARM-based devices.
Quote Unlike Windows Vista and Windows 7, there are no Starter, Home Basic, Home Premium, or Ultimate editions.
01-11-2013 8:08 AM
Quote from: HPsauce There's no equivalent with Windows 8.....
Technically yes, but they do resemble each other quite a lot (if you stick to the Windows 8 desktop). Neither comes with the ability to play DVDs. Neither has the attractive 'aero' appearance of Windows 7 (other versions).
01-11-2013 8:43 AM
01-11-2013 9:40 AM
01-11-2013 10:13 AM
Quote from: purleigh Whatever happened to the lightweight version of Windows that Microsoft said they were developing, to encourage customers using XP to migrate to a newer OS that would run on existing older hardware with limited resources, without needing to buy a whole new computer just to run Windows 7.
there was an xp version like that some years ago now called fundamentals. theres a lot of xp users still around.if its not broken don't fix it.
01-11-2013 11:51 AM
I suppose the codecs are within the GOMPLAYER software... not sure if the second dvd needed the AC3 codec, or if it was playing with the existing GOMPLAYER codecs...
Am assuming the original comment about not playing dvd`s was referring to a "basic" install of W7 Starter, and not using external progs as in my case....
02-11-2013 10:38 AM
