How to get WINE listed in the "open with.... context"
shutter
Fixes: 67
Just done a "new install" of Linux Mint 20 ULYANA with CINNAMON desktop 64bit
Also installed WINE5.0
This shows up in the Main menu listing .... but when I try to run a .exe program downloaded... by right clicking and using the drop down menu, I do not get the "usual" open with wine application  .  When I click on "open with other application.... "   WINE is not on the list ... so I cannot choose that...
How do I get WINE to appear in thee "other applications" listing. ?
3 REPLIES 3
VileReynard
Fixes: 20
Re: How to get WINE listed in the "open with.... context"
For a trial-run:-
Right-Click -> 'Open-With' -> 'Other application'
If this runs as expected,
1. Choose a Microsoft program.
2. Right-click -> properties, Left-click "open with" tab
3. Enter the name of the program, full path preferred(?) that you want to associate with this mime type.
[A .exe file is probably "Program (application/x-ms-dos-executable)"]
You only have to do this once if you choose "set as default" in step 3.
I don't know what WINE wants you to run, because I don't use WINE. 😀
shutter
Fixes: 67
@VileReynard  Obviously, did not read, or understand properly, what the problem was...
However.... I think it was caused by CINNAMON... as when I installed Mint 20 with MATE and WINE5   it worked perfectly... ...
VileReynard
Fixes: 20
Glad you got it working, anyway.
