How can I make a Custom Application Launcher for ....
shutter
Fixes: 67
How can I make a Custom Application Launcher for  ......    vnstat
I can run vnstat from the Terminal, by typing vnstat and the enter key. but I would like to have an icon on the lower task bar to run it from there.
I have tried to do this via the "Add to panel" > Custom Application Launcher  but it does not work
I have also tried to do it by using a clear space on the desktop and right clicking then choosing "Create Launcher" which brings up the same Launcher app as in previous sentence.
Running Linux Mint 20.3 Mate 64 bit
I have googled this, but it does not give any specifics, only the "above" solution, which does not work.
12 REPLIES 12
Fixes: 1,495
Re: How can I make a Custom Application Launcher for ....
can you not create a shell script and use that?
shutter
Fixes: 67
@dvorak Dunno... what one is, or how to construct it, or use it. Undecided
If it means I have to click on the terminal to use the shell script, then it "kinda" defeats the object, as I can run vnstat from the terminal..
Just wanted to be able to be "click happy" instead of having to type on the terminal ! ! ! .. Smiley
RPMozley
Seasoned Pro
Fixes: 16
You might be able to achieve what you want, by using Menu Libre (or sometimes known as Menu Edit/er).
Tap/click the plus button and fill it out. Look at existing ones to get an idea of what to put in the new launcher item.
That's RPM to you!!
shutter
Fixes: 67
@RPMozley  Thanks for the hint!.. checked out Menu Edit on Software manager, and it gives a similar window to the "add panel" for making a Launcher.
The problem I seem to have is that of using the correct "Command" .... on the Terminal, it is just vnstat and the enter key... but this does not actually launch vnstat.
should I be looking "somewhere else" for the "command" line ?  if so.... where ?
Thanks again
RPMozley
Seasoned Pro
Fixes: 16
Check the other app launchers. Also it might require the full file path to the executable.
That's RPM to you!!
shutter
Fixes: 67
@RPMozley  I did. !... they all seem to work with the launcher...
Where and how, do I find the "full path".....
I checked in the Home Folder and this is what is showing .
@shutter
not sure if you've found the answer but I would look in /usr/bin
Dan
shutter
Fixes: 67
@Dan_the_Van  WOW !   there`s a lot of stuff in that bin !
Found vnstat.... but alas... it did not work on the Launcher command line.
Thanks for trying
Wink
RPMozley
Seasoned Pro
Fixes: 16
If vnstat is this one https://github.com/vergoh/vnstat
Then it is command line only, no GUI. Terminal is required to view it.
There is a GUI available for vnstat. Not looked at it in detail but it’s there.
https://hulxv.github.io/vnstat-client/
That's RPM to you!!
shutter
Fixes: 67
@RPMozley  OK... thanks for the info.
as for the GUI.. do I have to unistall the current vnstat 2.6 version? or does this GUI attach itself  and update in the process of the install from the Terminal instructions on this page...
Scroll down to  Download and Installation
https://hulxv.github.io/vnstat-client/INSTALLATION.html
shutter
Fixes: 67
This fixed my problem.....Smiley      Thanks very much...   Smiley    works a treat.  Smiley
shutter
Fixes: 67
@RPMozley  @Dan_the_Van  & @dvorak
I have since found a much "nicer" network traffic monitor, ( for my purposes ) . It is called NETWORX
https://www.softperfect.com/products/networx/
It says it is "not free"... but you can download the "free trial" and if you disable "check for updates" in the settings, it will remain free. If you forget to disable the updates... you will get a notification of any updates, however..
IF you then go ahead and install the update, it will overwrite the "free trial version".. and become a paid for version.
( there is a warning box on the update page )
In Linux, you will need to right click on the "menu" listing and choose "Launch when I log in" for it to start up each time you are using the net, otherwise you will get a "false" reading on the "usage report"  ( also add to panel ! to access the "usage report" .
It is written for Windows and MAC... but will work on Linux through WINE . so not a big problem.
