Help ! Ethernet wiring signal loss
- Help ! Ethernet wiring signal loss
- « Previous
- 1
- 2
- Next »
Re: Help ! Ethernet wiring signal loss
16-10-2008 2:59 PM
Ideally it needs to work in France, so consider:
a) approvals
b) plug type
a) approvals
b) plug type
16-10-2008 4:57 PM
Thanks for the feedback. I had overloked plug type. But I see Solway offers a European 2-pin version. Also the Solway site gives a comparison between WiFi and Home Plugs - thanks for the link.
- « Previous
- 1
- 2
- Next »
