Wireless Router
Soxendom
Wireless Router
My brother wants me to get a wireless router so that he can connect using his laplop. My pc is connected via the ethernet port. Would a wireless router allow me to still connect as I prefer and let him connect via the wireless route.
Fixes: 62
Re: Wireless Router
yes
Fixes: 247
Re: Wireless Router
Most wireless routers come with ethernet ports as well, so yes.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Soxendom
Re: Wireless Router
Thanks - now only need him to cough up
Re: Wireless Router
Have a look on Ebay. There are lots of wireless routers to suit your needs, at really good prices.
Njal
Re: Wireless Router
Also try:
http://www.dsldepot.co.uk/index.asp?
Usually some bargains here, too.
Regards,
Neil
