Hard Drive Encryption
- Hard Drive Encryption
- « Previous
- 1
- 2
- Next »
Re: Hard Drive Encryption
31-12-2015 12:34 PM
My Gigabyte motherboard has this:
TPM (Trusted Platform Module) Header
You may connect a TPM (Trusted Platform Module) to this header.
31-12-2015 12:54 PM
So a TPM is a piece of add-on hardware? As here http://www.amazon.co.uk/90-C1B0AU-00XBN0VZ-Trusted-Platform-Module-Motherboard/dp/B007V9RQLY/ref=sr_... I presume.
31-12-2015 1:36 PM
It could be add-on or integrated depending on the vendor (and the perceived market, I guess - probably less likely to be integrated on consumer-oriented hardware).
Technet article on TPM Management (maybe a little out-of-date).
31-12-2015 1:39 PM
seems more common on laptops https://community.spiceworks.com/topic/398601-listing-of-laptops-that-support-tpm
02-01-2016 8:24 AM
From http://www.theregister.co.uk/2015/12/30/microsoft_hard_drive_encryption_keys/
I suspect that the vast majority of us don't have the hardware to support storage encryption so don't have to worry.
Quote You can download your key from here. If you can't see a key, and you're a Windows user, then your computer doesn't have the hardware – such as a suitable TPM module – to support the storage encryption, so you don't have to worry about any of this.
- « Previous
- 1
- 2
- Next »
