Hub one useing USB port as a print server.
bubblegum57
Does anyone know how to set up the Hub one, so that I can use the usb port for a print server.
2 REPLIES 2
bobpullen
Fixes: 315
Re: Hub one useing USB port as a print server.
I'm not sure this is easily achieved (the Hub One is very similar to the BT Home Hub 5 in many respects).
bubblegum57
Thanks,
