HELP!! Technophobe with WiFi issue
Woollybackmandy
Re: HELP!! Technophobe with WiFi issue
I succeeded!........ I didn't sit still !!!
shutter
Fixes: 67
@Woollybackmandy  Now you are a Techno GEEK ! ! ! ... yeee ha! Cheesy
Woollybackmandy
Ha! Ha!..... Maybe a step too far !!! Crazy
Thanks again Shutter
Fixes: 479
Excellent, well done! I have been out all evening so could not reply earlier. Presumably you now only have one Powerline unit connected to the router.  If you haven’t then you will probably have to pair the remaining one of the pair whose partner you have removed to the other connected units in exactly the same way. This is because if you bought them in pairs then the two pairs will have been working as two separate mains borne networks. If you need more help just come back.
