Graphics Card
jono
Fixes: 7
Graphics Card
Hi, I don't know if I'm in the right place for this question but here goes, I've got a Sapphire Radeon X1550 series Card in my Computer and have the LG Flatron L1919s Screen, the Radeon card has two connectors, one of which is a DVI, I'm sure I got an adapter with the card, I've had the card for a while now. Would it be of any benefit if I got a DVI cable and connected my screen via the DVI cable and adapter?  The LG screen has only one connector on it.
Any advice would be appreciated
regards
John          Smiley
3 REPLIES 3
HPsauce
Re: Graphics Card
Bluntly, no.
(assuming the monitor only has a standard 15-pin VGA connector)
jono
Fixes: 7
Re: Graphics Card
hi, Yes it has only the 15 pin connector, thanks for the prompt reply, saves getting new cable.
regards
john
HPsauce
Re: Graphics Card
If you want to understand, read this: http://en.wikipedia.org/wiki/DVI_connector
