Google Earth
Fixes: 9
Google Earth
I am having problems getting Google Earth to run on Linux Mint 16, everything downloads and runs ok for the first few seconds and then the program just disappears from the screen, in all fairness this may not be a Linux problem  but a nVidia Geforce (GTX660) graphics card problem. Drivers are up to date.
Google Earth is something I use a lot and it would be useful if I could get it to work, not sure if anyone can offer me any helpful advice on this problem, I Have looked on various forums and there are various opinions on this subject.
Found this useful site but it didn't solve the problem for me,
http://www.noobslab.com/2014/03/install-google-earth-in-ubuntulinux.html
Fixes: 4
Re: Google Earth
I'm also having trouble with the latest Google Earth running on "Trusty Tahr" 14.04.
Rather than a black screen, I get -
After that if I press OK, sometimes I get a black window, other times it will exit, and other times Google Earth will load and operate normally but not render any of the earth's surface detail - but will show boundaries, roads, places, etc.
The graphics chipset is Intel 945GM x86/MMX/SSE2, which has 3D and shader model 2.0 support.
I have tried installing the latest Linux graphics drivers from Intel, but that mode no difference.
I think the only real solution, is to find and install a previous version of Google Earth, but I've not found a copy yet.   Embarrassed
I currently have a slightly older Google Earth, running perfectly on an identical laptop, with "Maverick Meerkat" 10.10.   Roll eyes
Fixes: 20
Re: Google Earth
Just installed in on my system, no problems.
Using a Geoforce GT 610
You using the NV driver or the open source one?
Waldo
Re: Google Earth
Quote from: gleneagles
Have you tried launching GE from a terminal to see what errors it throws up?
Waldo
Re: Google Earth
Quote from: Hairy
Ditto here with a GeForce 8200 chipset and nouveau / mesa drivers
VileReynard
Seasoned Pro
Fixes: 11
Re: Google Earth
Works fine on a GeForce 210 - with nvidia drivers...
Fixes: 9
Re: Google Earth
Quote from: Hairy
Using the NV  driver.
Quote from: Waldo
No idea how you do that, despite using Mint most of the time I rarely use or know how touse the terminal other than for a few basic commands unless I copy and paste commands from others.
Fixes: 20
Re: Google Earth
Open a terminal,
Type in
google-earth<cr>
then watch the errors fly by  Wink
This is what I get:
hairybiker@Duo:~$ google-earth
[0512/161253:ERROR:net_util.cc(2195)] Not implemented reached in bool net::HaveOnlyLoopbackAddresses()
[0512/161254:ERROR:nss_ocsp.cc(581)] No URLRequestContext for OCSP handler.
----cut and repeat of last message cut ----------
[0512/161255:ERROR:nss_ocsp.cc(581)] No URLRequestContext for OCSP handler.
Fixes: 9
Re: Google Earth
Thanks for that but the error list would have little meaning for me.
Guess I will have to learn to live without it unless I can get an earlier version that is known to work.
Annoying because I did have an earlier version of Google Earth running on  Mint 12 or  13 a year or so ago on another computer.
VileReynard
Seasoned Pro
Fixes: 11
Re: Google Earth
It seems I'm not using Google Earth.  Grin
Have you tried https://www.google.co.uk/maps/@52.8382004,-2.3278149,6z
It gives you the maps functionality, anyway.  Grin
Fixes: 9
Re: Google Earth
Yes, that's useful. Thanks  Smiley
