GOMPlayer playlist
Mav
Fixes: 518
GOMPlayer playlist
I have saved a playlist for GOM Player but I cannot find a way for it to be loaded automatically when starting GOM. Each time I have to load it manually then play. I have checked the help guide and FAQ with no luck.
Can anyone help with this, please?
Forum Moderator and Customer
4 REPLIES 4
shutter
Fixes: 67
Re: GOMPlayer playlist
The only way to do that,..... methinks..... is to make a folder on the desktop.... say... " My GOM playlist number 1 "  or MY XYZ ( artistes name ) Playlist...
Put all the tracks you want to listen to/watch... in that folder ( as copies of orginals)... and then open the folder to  click on the first one.... Highlight" them all,  then right  click  and ..."Play"...  This puts them all on the GOM playlist  and will start playing the first one....
Mav
Fixes: 518
Cheers, shutter.
I think, for now, I'll just place the Playlist file on the desktop and drag that into GOM once running.
Gus
Right click the playlist and choose default program option and then select the gomplayer exe for it.  You might need to manually find it, usually it will be in C:\Program Files (x86)\etc
FTTP 500 regrade from Tues 28th November
Mav
Fixes: 518
It is set as default for GOM. I'll just place it somewhere convenient on the desktop for now.
I mainly use WinAmp but wanted to see if GOM matches up to it Wink
