Fritzbox New Software
mystreet1
Seasoned Pro
Fixes: 7
Just seen this for Fritzbox users
https://www.ispreview.co.uk/index.php/2025/07/broadband-router-giant-avm-rolls-out-fritzos-8-20-firm...
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
6 REPLIES 6
outcast
Aspiring Champion
Fixes: 19
Re: Fritzbox New Software
Update as of 1st August 2025, the v8.20 firmware is still specific to the Fritz!Box 7590
however over the last few days, Fritz! has made public a 'beta' release of firmware v8.10 for a variety of their routers.
mystreet1
Seasoned Pro
Fixes: 7
Fritzbox's have a new home
https://uk.fritz.com/
Rebrand to Fritz!
ExForce9
All Star
Fixes: 11
The October 2026 updates to Fritz!OS -
ISPreview : Broadband router giant FRITZ! releases FRITZ!OS 8.50 firmware
https://fritz.com/en/pages/update-news?product_group=FRITZ%21Box&product=fritzbox-7690
Although the above headlines are for Fritz!OS 8.50, mainly for the Fritz!Box 7690,
many forum members here use Fritz!Box 7530 routers, so this might be a good opportunity to check whether your device has the latest firmware installed, as there was an update to v8.25  just a few months ago that you might have missed -
The latest FRITZ!OS for the FRITZ!Box 7530.
Product: FRITZ!Box 7530
Version: FRITZ!OS 8.25
Language: Dutch, English, French, German, Italian, Polish, Spanish
Release date: 21/04/2026
Fixes: 388
I will no doubt get the 8.50 release when Zen let it through, not that I'm that bothered - 8.25 works.
ExForce9
All Star
Fixes: 11
It would be interesting to know whether Plusnet customers using second-hand ex-Zen Fritz!Box routers, still get firmware updates pushed from the Zen servers, or whether users need to manually get updates from the official Fritz! website.
Fixes: 388
I would imagine that if they have been factory reset, as required to use them on non-Zen connections, then they will need to go via Fritz!.
