Firefox 44
- Firefox 44
- « Previous
- 1
- 2
- Next »
Re: Firefox 44
30-01-2016 5:43 PM
update ,, Win 10 now likes my Dolby Home theater but not Utube ,, giving up for today Chill now with Santana on my headphones for a hour clear my brain
Re: Firefox 44
30-01-2016 6:09 PM
Quote from: Oldjim HTML5 is a site coding language and wouldn't be on your PC at all
Thank you OJ. I knew someone wolud have an answer for me.
Re: Firefox 44
31-01-2016 9:03 AM
Re: Firefox 44
31-01-2016 9:15 AM
Palemoon works on x64 only not on the 32 bit browser ?
Re: Firefox 44
31-01-2016 9:17 AM
Re: Firefox 44
31-01-2016 9:43 AM
Re: Firefox 44
31-01-2016 10:31 AM
Re: Firefox 44
31-01-2016 10:36 AM
Are you using the headphone sockets on the front of the case or are they plugged directly in to your sound card? If you're using the front you might want to disable detection on these.
Also, have you tried these : http://maxedtech.com/asus-xonar-unified-drivers/
HTML5, What does this show : http://hpr.dogphilosophy.net/test/
Re: Firefox 44
31-01-2016 12:18 PM
Going to try UNI driver,, UNI driver not compatible
Re: Firefox 44
31-01-2016 4:12 PM
Re: Firefox 44
31-01-2016 5:25 PM
i tried with Dolby disabled will try with set to stereo rather than 5.1 .
so far TBH best browser that plays everything ok is Palemoon x64 with no addons only thing is i cannot start BF4 from a x64 browser
Update Mook Utube plays through speakers on FF44 in stereo not 5.1
Re: Firefox 44
31-01-2016 9:10 PM
Re: Firefox 44
31-01-2016 10:46 PM
Same for the Headphones no point in having £2.99 B&M phones , these cost a bit more than the B&M but sound reproduction is www.scan.co.uk/products/qpad-qh-90-pro-gaming-headset-black-with-hi-fi-capable-53mm-drivers-for-supr...
So Yes my PC is used as my Media center
Re: Firefox 44
04-02-2016 12:34 PM
Mozilla support last reply to me
Thank you for being extremely diligent with the cleanup and retries!
This could be a manifestation of the 44.0 no-connection-crash-on-exit issue or a new 44.0 issue if a 64-bit build works but 32-bit doesn't. Some computers have this issue, and there is no word yet what exactly is the cause, so I can't offer a solution - the workaround is to go x64 as you have done, or to downgrade to 43.0.4 32-bit (no real loss there) until the problem is fixed.
- « Previous
- 1
- 2
- Next »
