Firefox 3.6.13 Tools/Downloads
- Firefox 3.6.13 Tools/Downloads
Re: Firefox 3.6.13 Tools/Downloads
24-03-2011 12:36 PM
df gives me much as yours but with the difference that sda3 is described as: /media/_home !! I think that this is all rooted in my formatting the partition before putting the /home into it. I had a fresh look at fstab in file browser and it does list sda3 not as I said above.
24-03-2011 2:14 PM
But I would still boot another pc with the cd and make sure it is a lt issue.
24-03-2011 3:47 PM
I am sure that all my old /home stuff is in sda3, you may remember that it appears as another drive and I can see all the data in it. I think that sda1 has its own /home with all the routine folders in it but definitely none of my stuff. The modification of the label of sda1 and the fact that it is seen as another drive would mean that / does not know that it is there I guess.
24-03-2011 6:39 PM
and that sda1 contains a /home directory.
I'm going to suggest that you add a line (on a temporary basis) to your laptop /etc/fstab
Quote /media/_home /_home ext3 relatime 0 2
After a reboot, try
sudo du --max-depth=1 -h /_home
Repeat for /home
Report back.
27-03-2011 11:13 AM
Thanks for that, I will be away from the keyboard for a couple of weeks but hope to survive and get down to business after then. Enjoy your peace in the meantime!
Regards.
Colin
26-04-2011 10:50 AM
Hols and consequental activities over! I can now report a bit of progress...I have successfully got all my old /home on to a USB stick at last!! I did not get much of any interest from your last post but thanks all the same. I did find some error messages, probably were my own fault but time ran out. You were quite right in your thoughts about the locations of the two "/homes", it was all a metter of the formatting of sda3 in the first place.
I now feel more comfortable in doing a clean install of 10,04.2, which may well resolve all my present issues. Following the earlier guidance I should than have the proper layout of the partitions in place with the now (presumably unformatted) sda3 labelled as /home. It remains to be seen what happens to the original contents I think. Is there any advantage in clearing out sda3 and allowing the installation to insert its /home into it and then installing the personal data from the stick to allow future access?
I intend to to take small steps at a time now!
Regards
26-04-2011 1:16 PM
See previous posts in this thread.
Before you start, plan on 3 partitions - I suggest you format all of these during the install as it is better to have your /home in a known state.
(You wouldn't format your /home partition in any future upgrade).
You will need:-
A / partition
A swap partion
A /home partition
I suggest that, provided you have proper backups, that just before you start the install, you use the CD to remove ALL partitions from your hard disk).
But please get back with your planned partition layout.
Are you in a position to ONLY restore data from your backup of /home - you will lose some application preferences/personalisation?
27-04-2011 4:39 PM
sda1 / ext3
sda2 swap no format
sda3 /home no format
Please clarify. Also is ext3 suitable as HB suggested?
27-04-2011 7:06 PM
Previous advice was based on your having created a separate /home partition - but you appear to have two of them?
I'm basically suggesting you destroy everything on your hard disk and start again.
A full Ubuntu install takes about 20 minutes with only one reboot, so if it goes wrong it's easy to repeat (unlike Windows)
Unless you have a known good separate partition which is solely devoted to /home my suggestion would be to install from scratch, creating a new (empty) /home in the process.
You would then need to copy your files from your backup to your /home directory - data files only.
27-04-2011 9:33 PM
Regards,
C
27-04-2011 10:32 PM
I don't think you will be asked to format the swap partition, though.
Ensure you use the manual (advanced) type of install, so you have full control!
28-04-2011 9:36 AM
From a BLANK Drive (in gparted select new Partition Table)
choose
one partition for / (30gb is good size)
one partition for /home (rest of the drive - the swap file size)
one partition for swap (2xram if less than 512Mb or if >2Gb you don't need it)
so assuming a machine with 512Mb of ram and a 100Gb HDD
/ = 30Gb
/home = 69Gb
Swap=1Gb
Whether you use ext3 or 4 is up to you there is no real performance difference on a normal machine.
28-04-2011 11:07 AM
Quote from: Hairy one partition for swap (2xram if less than 512Mb or if >2Gb you don't need it)
I disagree that you don't need swap if you have over 2GB RAM. Well, you don't 'need' it but I'd still recommend having it. The kernel swaps things that haven't been used for a while to disk if it's available, which keeps your memory free for things it's actually using. And if you do start doing memory intensive tasks, swap can give you a bit of extra overhead.
28-04-2011 11:22 AM
You could use 2x swap for as much ram as you have but why waste disk space if you will never use it?
(e.g. I have 3Gb of ram on this PC and 1Gb of swap, with 2 FF widows (with 10+ tabs in each), TB and several background tasks running I am using 1.2Gb of ram and ZERO swap)
28-04-2011 2:09 PM
Personally I use 2 x RAM for < 2GM RAM, and 2GB swap for anything else.
