Enable PHP CGI on my website
martincleghorn
Hey Do you think I could get PHP/CGI service enabled. I see that @bobpullen  is the resident wiz.
1 REPLY 1
bobpullen
Fixes: 330
Re: Enable PHP CGI on my website
Unless you already have access to the CGI webspace platform then you're out of luck I'm afraid. It's been many years since we offered the ability to create new accounts.
