Email links not opening
southken
Hi,  has anyone had the problem of not being able to open links in outlook emails?  It’s just started happening on my iPad.  The updates are all up to date and they open fine on my android phone.  Gmail links are opening ok it’s just outlook.
Thanks.
1 REPLY 1
Gel
Champion
Fixes: 29
Re: Email links not opening
I use BRAVE browser, and occasionally EDGE will try + set itself as the default. By clearing that,
O/look e mail hypalinks work, if they weren't before.
