Advertising Stickers
Fixes: 118
Just bought a new Chromebook to replace my 10 year old model.
Its brought up a question I've often pondered - can you remove the advertising stickers without damaging the case?
3 REPLIES 3
Shep41
Seasoned Pro
Fixes: 7
Re: Advertising Stickers
Really easy. I always find gently heating the labels with a hair dryer on a low setting to soften the adhesive.
Fixes: 118
@Shep41
Thanks for the tip about the hair dryer. Labels now removed.
Shep41
Seasoned Pro
Fixes: 7
Easy when you know how.🤣🤣
