Domain Pointed To Static IP - Router?
mrbeee
I have no idea what to do to fix this, but I have a domain pointed to my IP. The problem is, when I visit the domain, it shows my router page and not my Apache server. I know it is something in the settings, but no idea which settings to adjust. I have been searching and tried various things I found in the forums, but they are either very old and no applicable to my router.
Any help and guidance would be greatly appreciated, thanks.
3 REPLIES 3
Fixes: 585
Re: Domain Pointed To Static IP - Router?
On your router, You need to portforward the relevant port ( http & https if you use it ) to your apache server
mrbeee
You rock, cheers chap!
bobpullen
Fixes: 331
I would strongly suggest against having your router admin interface exposed to the Internet. What router are you using?
