Does anybody recognise this BT master socket?
VileReynard
Fixes: 20
Re: Does anybody recognise this BT master socket?
It's quite old - I took part in the trial run of FTTC. Smiley
Jaggies
@ejs
You're right - I was somehow confusing the first post with ADSL rather than VDSL.
I'll just get my coat...
VileReynard
Fixes: 20
The BT engineer arrived today as promised and he spent about an hour checking copper connections & FTTC speeds. Fixed a connector in the downlead and installed a Mk 4 socket that looks similar (but slightly different) to this:-
BT Mk 4BT Mk 4
Turns out my FTTC only runs at 30Mb/sec due to a cabinet fault - which a second engineer will have to fix.
He said that I only lose about 2Mb/sec due to being 150m from the cabinet - but that sounds too good to be true.
VileReynard
Fixes: 20
I noticed a couple of Openreach vans camped out next to my green box, all weekend.
Whilst, I don't believe this was solely for me:-
My download speeds used to be about 65 Mbits/sec and has recently been about 25Mbits/sec
It's recently achieved about 78Mbits/sec (reproducibly), so I downloaded a 100GByte file from a ftp site and everything seems fine.
Since I'm about 160m from the green box, 78MBits/sec seems rather good.
