Dheeraj Sudan & Meenu Hinduja-How do I set up my Plusnet Hub 2 router?
- Re: Dheeraj Sudan & Meenu Hinduja-How do I set up ...
13-02-2026 11:47 AM
Hi everyone! I am Meenu Hinduja and my husband Dheeraj Sudan, run a business. I have just received my Plusnet Hub 2 router and I am not completely sure about the best way to set it up. Has anyone here installed one recently? I really appreciate any tips or step-by-step advice that worked for you.
Regards
2 REPLIES 2
Re: Dheeraj Sudan & Meenu Hinduja-How do I set up my Plusnet Hub 2 router?
13-02-2026 11:50 AM
Exactly what are you not sure about? What type of internet connection do you have?
13-02-2026 1:57 PM - edited 13-02-2026 2:00 PM
You don't usually need to do much setting up! Just plug it in to your Openreach network outlet with the supplied cable, connect and plug in the supplied power supply, turn it on and wait. There should be instructions in the box the router came in.
What service are you on, full fibre (FTTP),
landline (FTTC)? How are you going to connect your devices to the router, Ethernet cable, Wi-Fi or both?
