DVD drive
shermans
DVD drive
I have just installed a DVD player on my desktop pc but get the following message when I try to load a DVD :
"Windows Media Player cannot play the DVD because a compatible DVD decoder is not installed on your computer."
Can anyone suggest please where can I get the appropriate codecs ?  I am running XP Service Pack 3.  The system only came with a CD drive and so I have added a DVD drive.
Help would be as always most appreciated.
8 REPLIES 8
thisoldman
Re: DVD drive
dear sherman: codecs usually refer to the ability of a program to play different types of files.
I am no expert but i guess that you have not installed the dvd drive correctly.
To test my assumptiond  d/l another free media player such as vlc and try again. If vlc wont play your dvd then its an installation problem.
You also ned to check your dvd drive in  device manager and see if there are any clues there, also check whether win med player has been chosen to play dvds
HairyMcbiker
All Star
Fixes: 21
Re: DVD drive
You need to purchase a dvd decoder to be able to play on M$ systems, some DVD drives come with an OEM version of one.
Or try <a href="http://download.chip.eu/en/AVS-DVD-Player-2.4.2.125_152055.html">here</a> (no interest just a google search) for a free one.
Oldjim
Resting Legend
Fixes: 63
Re: DVD drive
Windows Media Player on XP won't play DVD's without the correct codecs.
Did you get any free software with the DVD drive such as PowerDVD?
If not I would suggest one of the free DVD movie players
http://www.computerhope.com/issues/ch000826.htm
Fixes: 1,484
Re: DVD drive
VLC will play DVD's fine and is free.
Quote from: Hairy
No, really you don't.
johpal
Re: DVD drive
I second adiewoo's nomination of VLC; it plays virtually anything you throw at it, including .ts files from my Humax PVR. Get it here:
http://vlc-media-player.us/
shermans
Re: DVD drive
Thanks for all the replies.  The problem is that no software came with the DVD drive and I assumed that XP already had all the drivers built in !  Sad
Obviously, I was wrong.
HairyMcbiker
All Star
Fixes: 21
Re: DVD drive
Quote from: adiewoo
Well when I said purchase, it includes FREE things! It just cost's you £0 (and I did post a link to a free player  ;D)
johpal
Re: DVD drive
@shermans
Try finding the website of the DVD drive manufacturer and download and install the appropriate drivers.
@Hairy Biker
I added my comments on VLC as it is software I have experience with. Searching Google produces a bewildering plethora of choice; I just wanted to help reduce the shortlist.
