DDOS to my router
VileReynard
Fixes: 20
DDOS to my router
Why would someone attack my router continuously for the last several days (at least)?
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:02:57
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:02:44
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:02:33
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:02:19
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:02:09
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:01:58
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:01:48
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:01:35
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:01:23
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:01:13
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:01:03
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:00:50
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:00:40
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:00:27
[DoS attack: TCP SYN Flood] multi-source syn flood attack in last 20 sec , Tuesday, Oct 31,2017 23:00:14
etc...
9 REPLIES 9
7up
Fixes: 20
Re: DDOS to my router
Who have you been upsetting now? Knuppel
Browni
Aspiring Hero
Fixes: 61
Perhaps they know you?
Oldjim
Resting Legend
Fixes: 63
the anti fox hunting brigade Shocked
jelv
Fixes: 10
I think you can report that by email to [email protected]
Do you have the Plusnet firewall on?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
VileReynard
Fixes: 20
I don't have the Plusnet firewall switched on, I never had had.
A SYN attack uses random ports in an attempt to overload a connection.
My 65/18 connection was severely impacted at times.
I've just tried disconnecting the router for a few minutes and Plusnet have finally allocated me a new IP address.
So it is now "cured".
But if your IP address is x.x.89.61 then you may encounter problems.Angry
7up
Fixes: 20
So for your sins you've passed the buck to some other poor soul.
VileReynard
Fixes: 20
And after a few hours delay it followed me to my IP address (146.198.x.x) - there doesn't appear to be much point in secrecy since every man and his dog has decided to practice SYN attacks on it.
I expect the entire Plusnet IP range is being attacked?
It's so pointless, especially when I have no port forwarding.
A whois gives
whois 146.198.x.x
NetRange:       146.198.0.0 - 146.198.255.255
CIDR:           146.198.0.0/16
NetName:        PLUSNET3
NetHandle:      NET-146-198-0-0-1
Parent:         NET146 (NET-146-0-0-0-0)
NetType:        Direct Assignment
OriginAS:       AS6871
Organization:   INFONET Services Corporation (INFO)
RegDate:        1991-02-28
Updated:        2015-03-12
Ref:            https://whois.arin.net/rest/net/NET-146-198-0-0-1
OrgName:        INFONET Services Corporation
OrgId:          INFO
Address:        2160 East Grand Avenue
City:           El Segundo
StateProv:      CA
PostalCode:     90245-1022
Country:        US
RegDate:
Updated:        2017-01-28
Ref:            https://whois.arin.net/rest/org/INFO
Is this right?
Moderator's note by Mike (Mav): Full IP address edited in a public forum.
7up
Fixes: 20
 So get yourself a plusnet hubone. That has no visible logging so you won't be able to see the attacks to worry about them Tongue
EDIT: Actually it does log stuff.. sorry i only found that around 10 minutes later when trying to do something else in the admin pages.
Incidentally I have port 80 open and redirected to my desktop PC for the apache webserver. When i look in the database i can see loads of bots have been trying to exploit phpmyadmin setup script logs and various other things. People are out there scanning and attempting to attack all the time. In my case they make contact with the default host on my apache which has one web page and nothing else. My actual websites are all on virtual hosts and the admin site with phpmyadmin installed is on a virtual host only accessible to the local network.
I've accepted that they'll always be there trying.. it's just one of those things.
Mustrum
Fixes: 81
I would be checking my PC's/Laptops with Malwarebytes ad all the antivirus software I could find, there is a good chance that something on one of your devices is call somewhere to start these DDOS attacks.
As for the IP address, it is well known that PN have used other BT division addresses when they expanded their network, and that many of the IP address checkers are out of date. It can cause access difficulty's with some sites, but these seem to be getting less troublesome.
