Change my wireless key password for Plusnet,
lollberts
Hello all can anyone please help me... id like to change my wireless key password for Plusnet, There are people who live nearby that have sneekerly managed to obtain my wireless key, and i need to get them off my internet!
Many thanks for any advise!
6 REPLIES 6
MrCJLambert
Re: Change my wireless key password for Plusnet,
Hi lollberts, welcome to the forum!
What router are you using?
Yours,
CJL
Fixes: 118
Have a look at the following link and then "Setting up ..... router"
https://www.plus.net/help/broadband/
lollberts
Hi thanks for the reply. It's a Thomson router box. Not sure of the model?Huh
lollberts
Thank you Brian I will have a look to see if it fixes a problem and let you know on Monday as the computer is at work. It looks like it should do the trick though. Many thanks for the advice!
Alex
Fixes: 13
Does it look like this?
If so it'll be a TG585V7 I believe.
lollberts
Hi there, Yes thats the one!
