Connecting to internet on Bush LED television
mlc100
Hello, i wonder if someone can help.
I have bought a Bush television and it had a USB internet dongle.  I found my plusnet network, I entered the password but then nothing.
I went to advanced settings where it looks like i can enter the IP address the but digit layout is not the same as the IP address.  I was really looking forward to setting up netflix and iplayer.
For the record I have plusnet fibre.
Thanks in advance  Smiley
3 REPLIES 3
picbits
Re: Connecting to internet on Bush LED television
Try 192.168.1.15 for the IP address
255.255.255.0 for the subnet address
8.8.8.8 for the DNS
192.168.1.254 for the Gateway
mlc100
thanks for that. sadly didn't work 😞
picbits
You could try disconnecting from the wireless then reconnecting making sure you enter the WPA key with the correct case - i.e. capitals or not
Also worth a read through here :
http://community.plus.net/forum/index.php/topic,122172.0.html
