Connecting Humax PVR to the Internet
HPsauce
Aspiring Champion
Fixes: 5
Re: Connecting Humax PVR to the Internet
Indeed, you can buy them in all sorts of useful lengths, just measure carefully and allow some slack at each end - you can coil up any spare, but it won't stretch.  Cheesy
Unless you need to feed the cable through a small hole of course in which case you'll need to terminate onsite.  Wink
gleneagles
Aspiring Legend
Fixes: 17
Quote from: vilefoxdemonofdoom
Ring circuits commonly have 30A MCB's.
Mine don't............32 amp for garage, immersion heater , kitchen.
Plugs x 2. At. 16 amp. And 2 for lights @ 5 amp
We are born into history and history is born into us.
gleneagles
Aspiring Legend
Fixes: 17
thanks for the info about the ready made up cable lengths, guess this is the option I need to go for,
Thanks for the replies  Smiley
jelv
Fixes: 10
I'd be stunned if you had trouble with powerlines. In a previous house I had them connected to not only different ring mains but the ring mains were connected to different fuse boxes (but both fuse boxes connected to the same consumer unit/meter).  I also had them plugged in to 4 gang trailing sockets which you are also not supposed to be able to do.
When they only cost £15 with free delivery you haven't much to lose giving it a try!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
gleneagles
Aspiring Legend
Fixes: 17
Must admit I thought they were much more expensive than that but as you say, at that price it's worth a punt.
Have ordered same.
Thanks.
NB: Some of the ones I looked at were quite expensive, I wonder why there is such a high range of prices for these items.
jelv
Fixes: 10
The faster speed ones are more expensive, but I can stream HD quite happily on the ones I linked using my Humax HDR-1000S (they are way faster than my internet connection so faster homeplugs is pointless!).
drj
Quote from: gleneagles
The most  obvious solution would be to use extenders that plug into the mains circuit of the house  but there is a snag with that as we have 2. Ring circuits for the mains electrical sockets so that idea would not work.
As has been mentioned you should be fine. There may be two rings but they're connected at the distribution board.
