Connecting Humax PVR to the Internet
gleneagles
Aspiring Legend
Fixes: 17
I am trying to figure out the easiest and least expensive way to connect a Humax 1010 PVR to the Internet.
The TV  & PVR are in  the front room  but the modem is some considerable distance away and it would be impracticle to move it close enough to the  PVR  to allow a wired connection.
The most  obvious solution would be to use extenders that plug into the mains circuit of the house  but there is a snag with that as we have 2. Ring circuits for the mains electrical sockets so that idea would not work.
Seems that  even Humax own dongle is not a solution .
For some reason only a wired connection will work,
Any ideas or thoughts on this ?
We are born into history and history is born into us.
21 REPLIES 21
HPsauce
All Star
Fixes: 5
Re: Connecting Humax PVR to the Internet
I have 3 (believe it or not) of these sort of devices in my house (just don't ask why), 2 on terrestrial signals, one on satellite.
One is connected using a LAN cable, which is actually using about 30 metres of 4-core phone cable (CW1308) which runs happily up to 100mbps.
It is not at all obvious run along skirting boards etc., so much so that SWMBO has never noticed it!
The other two use TP-Link TL-WR702N devices (micro wireless routers) configured to connect to my PN router wirelessly and deliver t'internet via a local short LAN cable (comes with the unit) and powered from the USB socket on the back of the Humax which has no normal use.
I use these clever little widgets a fair bit to deliver a wired connection to devices needing a wired internet connection, e.g. PC's I'm repairing.
HairyMcbiker
All Star
Fixes: 21
If you can't use powerline units then your only option is a long cable.
I have a cable run from my back room (upstairs) to the livingroom (downstairs) and it is plugged in to a 5 port switch to feed all the bits down there.
HPsauce
All Star
Fixes: 5
Quote from: Hairy
Or as noted above by me.  Wink
VileReynard
Fixes: 20
Or
you could move the PVR/TV.  Cheesy
PeeGee
I second HPsauce: I use a Tenda W150M, which is similar to the TP-Link unit.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
HairyMcbiker
All Star
Fixes: 21
Quote from: HPsauce
]Or as noted above by me.  Wink
Yeah but we replied at the same time  Wink
HPsauce
All Star
Fixes: 5
That's why the forum has the warning about new posts.  Grin
MJN
Fixes: 5
Quote from: gleneagles
Have you tried?
VileReynard
Fixes: 20
Are your two rings on separate phases?
gleneagles
Aspiring Legend
Fixes: 17
Not sure what you mean by separate phases ?
In the mains junction box there are 2. Mcb's  marked at 16 amp for plugs,  there are of course a number of other mcb's marked for other circuits in the house.
HairyMcbiker
All Star
Fixes: 21
Mains comes in 3 phases (hence the name 3 phase supply). Normally you only have ONE in your house to stop someone connecting between them.
You might get away with using PL adaptors as long as it is one phase in the house.
Only large buildings likes hospitals is it normally an issue
gleneagles
Aspiring Legend
Fixes: 17
Quote from: Hairy
Is it possible to get cables in long lengths that are already made up  or is it a matter of  putting the necessary plug or socket on the cable yourself ?
VileReynard
Fixes: 20
Ring circuits commonly have 30A MCB's.
HairyMcbiker
All Star
Fixes: 21
You can get cables at any length made up.
My local £shop has even got Belkin 10/15/30M ones  Wink
