Computer Freezing
Fixes: 118
Computer Freezing
Apart from old age (June 2016) and running Win7 is there any reason for the computer to freeze and require the old switch off/ switch on routine to get it back up and running.
Happening at least once daily now - 3 times yesterday.
Before any suggests I buy a new computer I like Win7 besides which I also have an NUC box running Linux with Win7 in a virtual window.
41 REPLIES 41
cpc6128
Re: Computer Freezing
If windows 7 has the built in windows program "event viewer" then look at the application and system logs as they may have errors and warnings that may give a clue.
Champnet
Fixes: 21
Any clues in the Event Viewer  ?
There has been a couple of unofficial updates :
UpdatePack7R2-25.12.10 & UpdatePack7R2 26.1.15 (probably more.....)
@cpc6128 Beat me to it.......
pvmb
Champion
Fixes: 16
@bmc
Have you tried the 'usual'? Full disc scan, full memory scan, for faults?
Fixes: 118
Is this what you're looking for re Event Log - see attached file
I've run a Dsk Chk and full scan but only with Microsoft Essentials (I think that's what it's called).
RobPN
Fixes: 15
CPU overheating, possibly requiring thermal paste replacement?
Champnet
Fixes: 21
@pvmb  Can u install MyEventViewer from  https://www.nirsoft.net/
Fixes: 118
@RobPN
I have a silent nofan computer. I'm not sure if it has any thermal paste. See attached image.
RobPN
Fixes: 15
It will most likely have thermal paste, alternatively a thermal pad, between the CPU and its heatsink.
Fixes: 387
@bmc Does the computer have any temperature sensors?
RobPN
Fixes: 15
@jab1
Yes it will have, but unless already installed, Win7 will need a third party utility downloading to display the info.
richard_25
Give this a try.
open Task Scheduler and at the left hand side  look for Microsoft and follow the path to
Windows \ PI \ Secure-Boot-Update.
then disable it.
Restart your computer.
Fixes: 387
Understood, @RobPN . Even my Zorin laptop needed that, although there were a number of options. Honestly don't know if installed anything on my W7 machine, but I'd be surprised if  I didn't.
markhawkin
Champion
Fixes: 22
I think I might try adding a slow speed fan to the back of the case (where you would normally see a fan).
Overheating is a good theory.
Champnet
Fixes: 21
Having dealt with many hundreds of users and their boxes I’ve only ever seen one hardware failure, the A30 gate wouldn’t open, eventually learnt this particulate box didn’t have that option.  So unless @bmc  is an enthusiast who likes to change the hardware I’d suspect the OS or running software. Run the task manager at the side and watch for any ‘doubtful’ processes. Try a virus scan etc……
