Changing our WIFI router
- Re: Changing our WIFI router
03-06-2015 9:16 PM
Hi all,
I've recently been gifted a router (Netgear N-300) that was previously on a Virgin Media account.
I've tried to connect to it but won't.
Will this connect to our Plusnet ADSL? Do I have to change any of the settings? If so, how? Finally, is it worth changing it from the Thomson (TG585 v8) we currently have?
Thanks in advance
Howie
Thanks in advance
Howie
1 REPLY 1
05-06-2015 11:45 PM
Should do - provided you put the correct settings in.
It doesn't need to be connected to the phone line whilst you do this.
Likely to be a better router than Plusnet's offerings.
