Cannot update firewall settings
Giacomo
Hello all.
On a p.c., mobile, using the link https://www.plus.net/member-centre/broadband/firewall I can see that my firewall is set to off. Any other selection will not save.
I have a ticket open since 26th November but to date no movement.
I can no longer see this ticket, it was listed on my home page within Plusnet up until a week back.
Wondering if there's anything I can do this end and if others have this problem.
Regards.
1 REPLY 1
RealAleMadrid
Fixes: 68
Re: Cannot update firewall settings
@Giacomo This is a known problem and Plusnet have not yet found a fix for it. If you search the forum you will find more information.
See this thread ....
https://community.plus.net/t5/Everything-else/Plusnet-Firewall-issue/m-p/1851412#M27809
