BT Smart Hub 2 vs Hub 6 worth the upgrade?
onlyme4
My BT Hub 6 is playing up. Is it worth getting the BT Smart Hub 6 as an upgrade. Plusnet won't give me their white version so looking at a second hand one on Ebay.
2 REPLIES 2
Fixes: 1,495
Re: BT Smart Hub 2 vs Hub 6 worth the upgrade?
Not if you need to split the 2.4ghz and 5ghz wifi bands, that' can't be done.
Also the extra disks won't work with it.
Fixes: 475
@dvorak
A recent post by Bob P advised that you can use Smarthub 2 disks. Whilst the BT phone app doesn’t work you can use WPS to pair them.
