Can't see other devices on WiFi when using 5GHz
geo3geo
If I connect my laptop to the local wifi on the Plusnet hub at 2.4GHZ I can use winSCP or PuTTY to communicate with a Raspberry pi on the same wifi. If I connect my laptop to the hub at 5GHz I can't access the pi. Have a second pi - same problem. Can't see any possible cause in router settings.
4 REPLIES 4
Fixes: 249
Re: Can't see other devices on WiFi when using 5GHz
Are the IP details all being assigned by DHCP?
How do the devices attempting to connect?
I have just tried poking (pinging) some of my devices across the two WiFi bands ... and found that they are using IPv6!!
Also I cannot ping one of the cross band devices ... I need to dig deeper.
geo3geo
<<Are the IP details all being assigned by DHCP?
yes
<<How do the devices attempting to connect?
using winSCP or puTTY software on laptop
Router is just called Plusnet2, can't find any manufacturer ident.
Fixes: 249
I should have been clearer - connection by name or by network address?
geo3geo
By network IP address.
