Can't get home wifi calling to work Samsung A13
insussex
Re: Can't get home wifi calling to work Samsung A13
Yes with Vodafone however its not working, interested in the router firewall issue????
Fixes: 139
@Dan_the_Van wrote:
@insussex
I seem to recall you can force wifi calling.
First you need to turn 'airplane mode' on, then enable the Internet connection through you home network
Hopefully you should still get text messages
HTH
Have you tried this to see if wifi calling works?
My Broadband account firewall found in the members centre is set to 'Low' there are no changes required for a plusnet supplied hub
Fixes: 1,491
Moderators Note
Pointless and inflammatory posts removed.
insussex
And there's the fix thanks very much
RealAleMadrid
Fixes: 68
@insussex To assist others who may have this problem could you clarify which part of Dan_the_Van's post do you consider to be the fix?
Putting the phone in Airplane mode, which will work but my Iphone does not have to be in that mode, if WiFi is available WiFi calling is activated.
Or was it changing the setting on the Plusnet Member centre firewall?  This can be the problem because on the higher setting the firewall blocks the data protocol required for WiFi calling to work.
insussex
Confirming:
RealAleMadrid
Fixes: 68
@insussex  Thanks for the reply, it's surprising that you have to use Airplane mode.
