COM PORT query Mint 15
- Re: COM PORT query Mint 15
04-06-2013 5:46 PM
http://sealedblade.wordpress.com/2008/08/20/ubuntu-pl2303-usb-to-rs232-adapter/
Method 1
I have followed the Ubuntu route, and get the right result....
I have not installed the driver..... as it was originally for my Windows vista.... I have found this page
http://lxr.free-electrons.com/source/drivers/usb/serial/pl2303.c
And, as it is a Linux driver, I thought it would be best to use this... ( not yet done )....
should I just copy and paste it onto a terminal, or how do I get it to load ?
The USB/Serial adapter has been located by the system from the initial work as above,....
so once the driver is installed,
it should only be a matter of allocating the COMPORT number as was originally instructed ? ? ? ? or not?
04-06-2013 5:53 PM
To get a working one:-
In a terminal enter
apt install gnome-system-tools
enter your password and it should be in the menu as Users & Groups (ignore the User Accounts one)
As to your rs232 adaptor, why are you re-installing drivers? It has been found and is in use as ttyUSB0 no need to do anything with it, except get wine to recognise it.
04-06-2013 6:15 PM
Thought the adapter "needed" the driver to work,... but .... if you say not, then I am happy not to try to install the driver....
just get wine to recognise it, and the CWcom prog to use it !......
Progress is being made
04-06-2013 9:02 PM
so have managed to get Mint to recognise the usb/serial adapter, and did this in terminal.....
ls -l ~/.wine/dosdevices
Here is the result....
gerry@gerry-Inspiron-1545 ~ $ ls -l ~/.wine/dosdevices
total 0
lrwxrwxrwx 1 gerry gerry 10 Jun 4 16:28 c: -> ../drive_c
lrwxrwxrwx 1 gerry gerry 11 Jun 4 20:38 com1 -> /devttyUSB0
lrwxrwxrwx 1 gerry gerry 8 Jun 4 16:29 d:: -> /dev/sr0
lrwxrwxrwx 1 gerry gerry 8 Jun 4 16:29 e:: -> /dev/sda
lrwxrwxrwx 1 gerry gerry 8 Jun 4 18:54 f:: -> /dev/sdd
lrwxrwxrwx 1 gerry gerry 8 Jun 4 18:54 g:: -> /dev/sr1
lrwxrwxrwx 1 gerry gerry 8 Jun 4 20:40 h:: -> /dev/sdb
lrwxrwxrwx 1 gerry gerry 1 Jun 4 16:28 z: -> /
from that, I am assuming that Mint now recognises COM1....
Now all I need is some way for the app/program, to recognise the COM1 exists and connect when I choose COMPORT instead of KEYBOARD on the Config screen....
which, I presume, has something to do with this from earlier....
and more detailed instructions for this bit..... please.
Reading up on this you will also need to add yourself to the dialout group, to be able to access the com ports. And to log off/in again to get the changes updated. (Use Users & Groups from the menu)
as I now have "Users & Groups" available... I need to have instructions on how to do the above, please....
05-06-2013 6:42 AM
# adduser waldo dialout
Adding user `waldo' to group `dialout' ...
Adding user waldo to group dialout
Done.
In your case it would be sudo adduser.
05-06-2013 8:55 AM
(assume change waldo to gerry ! )
05-06-2013 9:46 AM
Been there.... done that..... still not working....
the prog does not "see" the comport .....
05-06-2013 9:54 AM
Have you looked at the Ham radio section of Synaptic to see if there is something there that would be useful?
05-06-2013 9:59 AM
second query.... no, I doubt if there is... this is a " chat " type prog.... that can use a morse key to send the letters , or the keyboard as normal... not specific to "ham radio"...
05-06-2013 10:06 AM
( have also unplugged the adapter a couple of times, and still no recognition )....
05-06-2013 10:24 AM
Quote from: shutter
Your com1 symlink is broken. You missed the / between dev and ttyUSB0. /dev/ is a directory, ttyUSB0 is the device in that directory. You will need to remove the incorrect symlink then try again:
rm ~/.wine/dosdevices/com1
ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com1
05-06-2013 11:04 AM
gerry@gerry-Inspiron-1545 ~ $ ln -s /dev/ttyUZB0 ~/wine/dosdevices/com1
ln: failed to create symbolic link ‘/home/gerry/wine/dosdevices/com1’: No such file or directory
total 0
gerry@gerry-Inspiron-1545 ~ $ cd ~/.wine/dosdevices/
gerry@gerry-Inspiron-1545 ~/.wine/dosdevices $ ln -s /dev/ttyUSB0 com1
Going out now before I do anything else .... so will log off and see what happens when I boot up again... ( about 1 hour or so)
05-06-2013 12:38 PM
Thanks very much guys for all your help....
. it now works .... BRILL !... am so pleased....
Linux Mint 15 is looking good.... !
It is good that WINE work so easily, compared to all the faffing about that went before !..
05-06-2013 12:42 PM
Glad it is working for you, awaiting your next problem
05-06-2013 12:42 PM
Quote dmesg | tail
