Blue Screen - White text !
- Blue Screen - White text !
- « Previous
- 1
- 2
- Next »
Re: Blue Screen - White text !
25-01-2014 8:58 AM
(going out shortly, will do the sfc /scannow when I get back).
25-01-2014 1:27 PM
Just done the sfc /scannow did not show anything ...
25-01-2014 3:01 PM
lets take a moment to recap (noooo, not asking for uploads to be recapped)
CHKDSK /F /R came back clean
SFC /SCANNOW did not find any integrity violations
Have you got the famous free CCleaner to clear out any residue that builds up during daily use
25-01-2014 3:27 PM
This morning it booted normally, and again when I came home at lunch time... it booted normally, too.. so maybe it is cleared up now...
( I have uninstalled MSE and re-installed Avast.... in doing so, Windows has re-instated Windows Defender )...
25-01-2014 3:32 PM
Fingers crossed it is all sorted
25-01-2014 3:47 PM
26-01-2014 6:58 AM
Select the Advanced tab then click Settings under Startup and Recovery.
Under System Failure remove the check mark against Automatically Restart.
Everyone should do this; it's one of the Windows defaults that is just wrong. Now, if you encounter a 'Blue Screen of Death' again, the text will stay on the screen you you can read what it says. Depress the power button to switch-off the computer after you have done so.
26-01-2014 9:31 AM
26-01-2014 10:50 AM
29-01-2014 9:04 PM
minidumps created by Windows (XP & 7 don't know about Vista):
http://www.nirsoft.net/utils/blue_screen_view.html
as you will see on the site, it will recreate the BSOD and list what processes were
running at the time.
29-01-2014 10:05 PM
Quote from: shutter Yeah, but....... if you get the BSOD.. it is already corrupted ? No???
Not really, it could just be a memory violation from a windows driver or something which another process depends on. Quite common if you program stuff to encounter this inyour own programs (invalid pointers, objects that have already been freed, etc) but when it's part of the system and something screwy does something it shouldn't at the wrong time then it screws over any other processes depending on it and the next thing you know windows throws a boo boo.
Got to be honest, in the 2.5 years we've had this Win7 PC, I don't ever recall a crash. There might have been one and possibly another time I forcefully restarted it via the power button but nothing major or often.
Think this box has been runnnig around 3 weeks now since the last restart..
- « Previous
- 1
- 2
- Next »
