Windows Deployment tools
shutter
Fixes: 64
Just been into my Absolute Uninstaller, and noticed that Windows has installed...
Windows Deployment Tools on 24/1/2014
and
Windows PE x86 x64 wims
What are they? What do they do?
2 REPLIES 2
ejs
Aspiring Hero
Fixes: 25
Re: Windows Deployment tools
Probably happened when you re-installed Avast, I guess Avast uses them to create its bootable rescue disk.
7up
Fixes: 17
Windows PE might be a similar thing to BartPE - a kind of windows system that isn't windows but will suffice in an emergency to get the job done as it were.
I never touched BartPE myself but it did look interesting.
