Basic soundcard
Rourkefamily
Basic soundcard
Can anyone recommend a cheap and cheerful soundcard?
All I want it for is to hear audio downloaded from interviews on sites such as BBC.
Anything good off ebay or somewhere else.
7 REPLIES 7
VileReynard
Fixes: 20
Re: Basic soundcard
Don't you have one on your motherboard?
If you feed it out to a couple of small active speakers it will be loud enough.
Rourkefamily
Re: Basic soundcard
I thought I had but can't get anything out of it. I have connected speakers but nothing. Maybe I have blown that part of the board  Undecided Everything else works find.
Peter_Vaughan
Re: Basic soundcard
Or you don't have the correct sound drivers loaded. Go to the mobo manufacturers website and download the sounds drivers and see if that gets you going.
Rourkefamily
Re: Basic soundcard
How do I find out the make of the motherboard. Through Control Panel and System?
VileReynard
Fixes: 20
Re: Basic soundcard
Have a look at the BIOS information on startup - possibly go into the startup info (but don't change anything).
You probably have to hold the delete key (or similar) down to get into your configuration.
It should then reveal it's name and model  - or at least something cryptic that you can google for.
StickyMick
Re: Basic soundcard
Could be disabled in the BIOS.
There's a great piece of software here: http://www.gtopala.com/siw-download.html that tells you everything you need to know about your PC, including motherboard manufacturer.  Wink
7up
Fixes: 17
Re: Basic soundcard
There is nearly always someone on your local freecycle who's sitting on a stockpile of computer parts... Thats always my first port of call for anything I need.
